Cruise and TCS quit at the same time
Old 02-01-2011, 07:37 PM
topfig1's Avatar
Default Cruise and TCS quit at the same time
My cruise quit working and traction control started acting up at the exact same time. Anyone else have this problem and does anyone have an idea what it could be?
Angel
Old 02-04-2011, 04:57 AM
rdd014camaro's Avatar
I had a similar problem with mine. Cruise didn't work and traction control would go out. There is alot of things that can make these go out... Third brake light out, faulty clutch or break peddle switches. Mine turned out to be my EBCM(electronic brake control module). One of the relays was going bad in it. Not a cheap fix ether haha. Anyways if you have a reasonable shop in mind that has a scan tool they should be able to tell you exactly what it is. And it can't be just a regular obd2 scanner. It needs to be one of the expensive ones
Old 02-04-2011, 05:52 AM
eseibel67's Avatar
Check the TCS fuse and the stop/hazzard fuse.
