Stall Question
Stall Question
Was going to do the Yank 3600 that so many brag about, but has anyone used this?
http://cgi.ebay.com/ebaymotors/4L60E...item1e61168c64
Earlier discussion of these folks:
https://ls1tech.com/forums/lt1-lt4-m...ard-stall.html
Some have had great luck on mild to moderate builds, I'm holding out for Circle-D 245mm 3200 since I'd want a couple of upgrades these RevMaxx folks would recommend, and would only be a couple hundred less than a Curcle-D...
is it the one in the top picture or the picture below? i would save your money. when you cheap out on an important item like a converter it usually will bite you later on. it doesnt mean you have to go with just yank. theres other good companies out there. This is an item that could give you better results then the cam you put in. dont cheap out.
The top picture is what appears to be a billet converter. You will be buying the one at the bottom. Look in the auto transmission section, in the sticky and see "torque converter education" thread. There are also a couple of big revmax threads that turned into huge pissing matches that are interesting reads
