New LS1 Owners - Newbie Tech - Damn fans!
danbrazda
02-02-2011, 07:26 AM
My cooling fans are driving me nuts with their obnoxious squeaking. Assuming there is no way to lube them to shut them up, can anyone recommend a good aftermarket alternative to the stock fans? Am I better off sticking with stock ones?
ULTIMATEORANGESS
02-02-2011, 08:24 AM
i had stock ones replaced under warranty yrs ago and theyve been fine.
Stock fans don't seem to be an issue around here. I would get an aftermarket set if it was cheaper, but that's the only reason I would go there...
zracer323
02-02-2011, 07:18 PM
If you can't find the source of the squeaking, I would just go with a used stock set. No need to go aftermarket for fans.
danbrazda
02-04-2011, 08:50 AM
Source of squeeking is definitely the fans. Can the fan assembly be pulled out from underneath or do you have to do it topside?
Magnet
02-04-2011, 09:48 AM
I have a used set for sale, PM me if interested.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
