Low oil light on my ls1 swap help
ls1 in a 95 formula
ive already grounded the wire and still comes on at first start up but on second start will stay off..
anyone know how to delete it with out check gauges turning on..
taking out the bulb??
A small resistor should do the trick, just a matter of finding the correct resistance to use. Someone with a working sensor and an Ohm meter should be able to tell you.
