10 Second Club - what does it take to hit 10s in a fbody?
00 black ss
02-03-2011, 05:30 PM
Like the title says what does it take for a fbody to make it to run 10.50s to 10.70s. My mods are in sig and I'm really trying to hit 10s in spring. But I'm going to be picking up a set of trickflows or afrs and a FAST 92/92
Magnet
02-03-2011, 07:10 PM
no sig
blackls1ta00
02-04-2011, 04:09 AM
lol a sig would help.
baalic
02-04-2011, 05:51 AM
Acording to GM high-performance a ms3 full bolt ons stock head and bottom end and a 200 shot!!! Like 9.7 I think..
MillerTime85
02-04-2011, 05:53 AM
that would be 9's........
baalic
02-04-2011, 06:15 AM
So minus the spray.. But would you really complain with a 9.7 with cam only and boltons
00 black ss
02-04-2011, 08:19 AM
sorry guys idk why my sig dosent show when i first make a thread...but here you go
DopeFedLSX
02-08-2011, 12:34 PM
put that 92/92 setup on it with a little shot of juice ;)
highmattz28
02-08-2011, 01:37 PM
Spray!!!!!
MillerTime85
02-08-2011, 03:39 PM
Just messin with ya.I would not be upset at all.
samdogmx
02-08-2011, 08:44 PM
in my case all it took was a 2900# car & a 100 shot to go 10.43
so id say do some weight reduction
jc98ss
02-08-2011, 08:48 PM
then some more $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ :secret2:
Carter01
02-08-2011, 08:52 PM
28 inch slick and a 150 shot will get you there easy if you can row.....
baalic
02-08-2011, 08:57 PM
I also made a mistake I believe it was 9.3 with bolt on/cam and stock head and bottom end.. "with juice". My copy of GMHTP is not with me but Somone who has this months can prolly list full spec from the mag..
Carter01
02-08-2011, 09:01 PM
Good friend of mine, Cameron. 9.5 at 142. Stock long block minus cam, it has a MS3 with an FTI converter, Th400 tranny. Very nice and fast car....
1BAD98LS1
02-09-2011, 05:01 PM
When you get the 92/92 have the intake ported for sure. I dont see why everybody says spray, shouldnt need it with the current mods and the new mods you plan on getting, especially if you got the good driver mod :D
donedidit
02-15-2011, 02:08 PM
Can you post a link to that I must have missed it...
SSHAWK
02-18-2011, 01:38 PM
Only one person into the 9's cam only and he ran a 9.98@132.17
http://www.ls1tech.com/forums/drag-racing-tech/1354787-9s-cam-only-new-record.html
I say spray it and have fun.
00 black ss
02-19-2011, 09:33 AM
going to hold off on the heads and just pick up a used 90/90. getting the bigger lid and 85mm maf. and some lcas, subframes and a drag bar. hopefully that will get me in the 10s. during the summer il throw on spray and get some prc 227s
SSHAWK
02-19-2011, 11:28 AM
Have you taken the car to the track ?? Would be nice to have some numbers to go off of. So we can tell you how close the mods you listed will get you to your goal.
Suspension sponsor will say Lca will get you a .1 tenth
92/92 with lid 1 to 2 tenths
Drag bar will drastically improve 60-foot times as well as consistency.
So total
lca...... .1 tenth
92/92 and lid ..... .2 tenth
drag bar....... .1 tenth
4 tenths of a second.
If you run low 11's right now you might get there but would be nice to see what your times were before.
Again this is just my .02
You could have a lot better 60ft and get it even better I just don't know.
ls1curt
02-19-2011, 06:11 PM
i bet you would be high 10's right now depending on your 60 ft. i was an 11.3@125 with a 383 and prc 5.3 heads/ms4/fast 90 and a slipping clutch. 00back SS- just send your 243's to a.i. and you should be easy 10's
odarabla
02-19-2011, 08:39 PM
With a little spray you can reach your goals.
00 black ss
02-21-2011, 09:52 AM
So total
lca...... .1 tenth
havent ran the car since i swaped motors. my old setup was just a ms3 bolt on ls1 with 4.10s and shit 10 bolt and i ran a 12.0 now everything is upgraded from that setup.
SSHAWK
02-24-2011, 11:20 AM
Yeah when you change everything its kind of hard to give you some numbers but..... with what you have if everything goes right you should be close.
Good Luck let us know how it goes.
