ABS INOP light came on last night...
Old 02-12-2004, 12:55 PM
1F8TL02WS6's Avatar
Default ABS INOP light came on last night...
Well I guess it is just a coinicidence that I just put my headers on now my ABSINOP light came one. What causes this? I think the fuse just blew or something? could that be it? The only thing that rubs is my catback on my heat shield a lil bit, and MAYBE but im not sure yet, when i get on it and the car squats hard cause of the HALS my midpipe might be hitting my driveshaft. Does this have anything to do with it? or what causes this? could a senor be unplugged somewhere that I need to check, or start off with the Fuse, I wont have time to deal with it until tonight so that is why im posting now. thanks alot guys.
Old 02-12-2004, 01:15 PM
ta12sec's Avatar
First check your fuse. Many things could cause this. Low tire pressure, damage/unplugged abs sensors, damaged or full of crap tone rings, abs module failure ect ect. check your fuse first then check all your plugs for your abs sensors then go from there.
Old 02-12-2004, 01:30 PM
1F8TL02WS6's Avatar
where are all the plugs for the ABS sensors located? by each brake assembley?
Old 02-12-2004, 01:34 PM
felton316's Avatar
The front passenger ABS plug wires run down the stut tower, right next to the headers. Check to see if you burnt through this wire or maybe unplugged it while installing the headers.
Old 02-12-2004, 03:22 PM
1F8TL02WS6's Avatar
ok thanks alot man.
