4l80e seals ?
4l80e seals ?
I am rebuilding a 4l80e and i have messed up a few of the seals. Does any one know where i can find these seals without buying a complete kit. Here are some pics of the seals
Moderator
You can get those from Whatever it takes transmission parts(WIT). They are what is call turbine shaft Teflon seals. The smaller ones are for the forward clutch drum and the larger ones are for the stator tube. The next time you go to install them use the drum and the pump to size them so you do not have this issue again. Make sure to let them sit in these components for a while and you should be good to go. HTH Vince
