to those running nitrous main line down pass side of the car
how did you get the mainline into the engine compartment?
I have the line ran all the way up to the tire well...now i need to get it into the engine compartment as simple as possible
thanks
matt-
thanks
matt-
I'm assuming you mean outside of the car. If so, I went through the frame into the fender well, ran it over the top of the inner plastic wheel well, into the bay from the opening by the battery.
i had my bottle in the spare tire compartment, rand the hose through the inside of the car, under the passenger carpet, through that body plug, around the converter shield, over the k-member and up to the bottom of the air filter. this is a little bit harder but once done you can not see it at all.
Mine is inside my spare tire compartment. All I did was run the line inside the car down the door, and up through the hole in the firewall. It was simple. Remove one interior panel and you're there.
