purchasing my cam, what else will i need?
Old 02-05-2011, 06:20 PM
Palomba's Avatar
Default purchasing my cam, what else will i need?
I got a cam speced for my LQ9
I need the cam for $409
but what else do i need. Comp recommends there beehive springs and pushrods, says they are a must. Do i need anything else?
LQ9 with 317 heads.
car will be running performer RPM dual plane intake, stall, 700r4 headers, and the cam
grind # 3718/3705hr110+4
Old 02-05-2011, 06:28 PM
Slash8915's Avatar
Springs, pushrods, lifters, oil pump, timing chain...
Old 02-05-2011, 06:34 PM
Palomba's Avatar
damn was hoping to avoid all of that ha.
the only thing kicking my *** is rewiring this hoe. I may get some cash together and get some of you LS1tech guys to give me a hand.
Old 02-05-2011, 06:41 PM
Slash8915's Avatar
Yeah you definitely want to do it right the first time. Say you get the cam installed and after a few miles one of your lifters breaks. Your new cam is basically destroyed.
Old 02-05-2011, 09:22 PM
NemeSS's Avatar
U lookin for a ignition box?
Old 02-05-2011, 10:31 PM
5w20's Avatar
LQ9 with 317 heads.
if you are mechanically inclined and its not too high mileage you can get away with valvesprings and pushrods.
Old 02-06-2011, 12:09 AM
westtexasbuff's Avatar
Cam, valvesprings, and pushrods are all you NEED... everything else like the timing chain, oil pump, and lifters are optional. Don't chimp out on the valvesprings, get some patriot duals, beehive springs suck.
Old 02-06-2011, 12:32 AM
winters97gt's Avatar
Depending on miles, I would upgrade as much as possible when at it. Oil pump, lifters, rods, chain, etc.
Old 02-06-2011, 01:12 AM
red90cobra's Avatar
seats and retainers for the springs if you can't use the factory ones
Old 02-07-2011, 03:27 PM
Robert@G-Force's Avatar
Cam. pushrods, valve springs are the neccesities, oil pump timing set are easy to swap since your there. As for the lifters that requires a bunch more work and parts, you'll need head gaskets and bolts for the lifter swap, also dont forget a front cover gasket set for the cam swap.
Also do not use beehive valve springs use Patriot part number 8401 or an equvalent double spring.
Old 02-08-2011, 10:08 PM
Palomba's Avatar
yeah still need the MSD 6010
Gforce sell all the stuff? Il stick with yall if you do.
Old 02-09-2011, 09:33 AM
Camaro Junky's Avatar
You gonna do the install?
Old 02-10-2011, 08:46 PM
Palomba's Avatar
Im going to try lol, this is all a learning experience for me. I got pretty much every tool i should need. And catch on fast. I will end up finding a friend i can trust to do solid work come help if i can.
