Launching with 3.73's & ssf3500
Old 02-12-2004, 03:53 PM
Z'mnypit's Avatar
Default Launching with 3.73's & ssf3500
Any body running this combo. If so what rpm are you launching at? Im running Nitto t555r exterme drags... Ant tips or suggetions?
Old 02-12-2004, 04:38 PM
boomcase's Avatar
Yea its going to be a learning curve for you with those gears and converter on nittos, You might have to feather it out the hole and then get on it hard , its trail and error to see what works best for you.
I run the smaller 2800 stall with 342s and i cannot launch full throttle on my nittos, my best launches are usually around 1800rpm about 3/4 throttle then once i get the bite and rolling alittle it to the boards with the pedal.
You have a few things against you with the 373 gears and the sportline springs, you need to have relocation brackets on your car , especially if its lowered. The will help you bite out the gate better, I would recommend lower control arms and relocation brackets , that will help you somewhat , but I really think with 373s and a 3500 converter you are gonna need better tires, (slicks)
