Is it bad that I can change transmissions faster then I can do an intake gasket swap?
Old 02-06-2011, 01:14 AM
whytryz28's Avatar
Default Is it bad that I can change transmissions faster then I can do an intake gasket swap?
Just did my gasket swap and it was ~2 hours including a 20mins part trip, while I swapped out my trans in 1 hour and 27 minutes by myself and a floor jack.
Comment.
Edit: yes im bored as hell.
Old 02-06-2011, 04:27 AM
boostedlt1's Avatar
damn that's pretty quick on the tranny drop! the last time i had mine out i think it was about 2 hours, that was my 5th time i think.
intake gasket took me longer than my tranny as well; granted i was messing around with it, seeing how hard it would be to port
Old 02-06-2011, 08:53 AM
moderate Z28's Avatar
Since your so quick, I'll ask how do you go about getting the top bolts out of the bellhousing?
Old 02-06-2011, 09:46 AM
Badazz 97 TA's Avatar
Theres only three on each side for the LT1. no top bolts. there easy to get to.
Old 02-06-2011, 10:23 AM
SoxXpupPeT's Avatar
for my T56 i use about a 3' extension and ratchet from the back of the tranny. best way for me.. but it would certainly take me longer then that lol
Old 02-06-2011, 12:25 PM
CamaroRacing12's Avatar
we talkin a 4l60 or a T-56? 4l60's r a bit difficult
Old 02-06-2011, 12:43 PM
camar0corey's Avatar
I wish I could have the trans in and out in a hour and a half. I've got it down to a one day project now, which I thought was good.
Old 02-06-2011, 01:04 PM
RamAir95TA's Avatar
I think it takes me about that long to remove the trans (4L60E). Let's see...
Six bellhousing bolts - LONG extension
Four cross-member bolts
Two cooler lines
Four pinion yoke nuts for the driveshaft
Dipstick
Wire connection
Linkage
Done. Yeah, about a half hour to pull it out probably.
Old 02-06-2011, 01:07 PM
i've only pulled it once and it was easy except for the trans lines stripping.
Old 02-06-2011, 01:19 PM
355z28's Avatar
Back before I switched builders I went through 7 in 2 years. I could have them swapped in about 45 minutes to an hour.. Of course that was with a 2 post floor hoist.
Luckily I havent had to touch it for 2 years other then maintaining it.
Old 02-06-2011, 01:38 PM
Really? Thats it. Good to know. I was just wondering because Im going to be getting that stall soon.
Old 02-06-2011, 02:04 PM
boostedlt1's Avatar
from the tail shaft area use a rrreeeeaaaallllllyyyyyyy long extension.
also having a tunnel mount torque arm makes it a lot easier
Old 02-06-2011, 02:32 PM
TheTransporter69's Avatar
I didn't think the trans was to bad, granted it took me a long time but hey it was my first time doing it. I dont know how you guys get the top 2 bolts with long extenitons i tired that and couldn't get it to work. I found it easier to just lay on the motor and sitck a wrench down behind the motor and get those 2 bolts. Yes it takes a long time and is hard on the hands but it worked for me. I hated the trans cooler lines too those where kinda of a bizzatch.
Old 02-06-2011, 05:02 PM
whytryz28's Avatar
4l60 trans
I lower the rear tail housing and get the top bolts first then work my way down. takes like 10 minutes.
Old 02-06-2011, 05:15 PM
boostedlt1's Avatar
Originally Posted by whytryz28
4l60 trans
i lower the rear tail housing and get the top bolts first then work my way down. Takes like 10 minutes.
^x2
makes it easy
