Tools & Fabrication - What is this damn thing called?
The Bronx Bull
02-06-2011, 11:20 AM
I need one of these for a tight space; what is it called? Tried searching: Phillips wrench, phillips key, phillips L-shaped, etc...
http://i789.photobucket.com/albums/yy176/TheBronxBull9/phil.jpg
Ryphraph
02-06-2011, 12:22 PM
Offset screwdriver...
Ryph
The Bronx Bull
02-06-2011, 12:47 PM
Ryph
:usa:
stimpy
02-07-2011, 02:51 AM
one of them goofy screwdrivers I have about 10 of in my tool box with no use for ..
oh a little tip for using one to keep it from popping out of the phillips cross put a little toothpaste like colgate on the tip as it fills it in and the grit prevents it from slipping out , the toothpaste washes off without damage . or you can use real fine valve lapping compound . but it takes solvent to remove it .
Silverback
02-07-2011, 03:54 PM
Polishing or rubbing compound works also, at least about as well as anything else... (which is to say that nothing really works great with those things)
silversrtman
02-08-2011, 02:04 PM
whats the point of those? I always see them, is it just getting in tight spots? or something else?
stimpy
02-08-2011, 09:39 PM
I think the proper name of it is the engineers revenge device . I only had to use one on some moulding on a car a long time ago , like I said I have about 10 of the things in the screwdriver drawer from all the sets I have boughtover the years , wait hold on .. damn I think one is pregnant ...
396D1SS
02-08-2011, 10:18 PM
you can buy them at home depot or lowes for a dollar fwiw
axon360
02-13-2011, 12:35 AM
I got a set of 3 ratcheting screw drivers off the matco truck for around $25 that work wonders!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
