FS: Custom Fiberglass 12" Subwoofer enclosure + Complete >$2000 Audio Setup
I'm selling all my car audio equipment. I'm located in Houston if someone wants to pick up locally.
Email: physiphile@gmail.com or call/text at 832.390.1414
NINe.1 is $215 and NINe.2X is $145 + shipping.
NINe.1
Number of Channels : 1
450W x 1 @ 4 Ohm, 900W x 1 @ 2 Ohm
1200W x 1 @ 1 Ohm
Length : 15.875" - Width : 9.850" - Height : 2.250"
NINe.2
Number of Channels : 2
400W x 1 @ 4 Ohm, 200W x 2 @ 2 Ohm, 100W x 2 @ 4 Ohm
Length : 12.000" - Width : 9.850" - Height : 2.250"
Complete high end CDTAudio setup. If you know car audio you know this is top notch equipment. MSRP is $600 for ES-07 mids, $250 for EX-560i crossover, and $200 for DRT-26 Aluminum tweeters for a total of $1,050. One of the ES-07's has been repaired but sounds perfect. I'm asking $575 for the entire setup.
EuroSport-07
Diameter: 7” (180mm)
Sensitivity: 92.2 dB
Power Handling: 100 Wrms (200W pk)
Frequency Response: 50 ~ 5000 hZ
Nominal Impedance: 4 Ohms
Voice Coil Diameter: 1.5” (38mm)
For sale are two AudioControl EQT 32 band equalizers for $195 in perfect working order.
Ascendant Audio Avalanche 12" subwoofer (~800wrms). The price is $145 + shipping.
(Avalanche is on the left)
I made this enclosure for the subwoofer I'm selling above. It's not pretty because it goes into the spare tire spot and can't been seen but you can always paint or carpet it. I'm asking $145. And I'll include the rear plastic for an additional $45.
NINe.1
1200W x 1 @ 1 Ohm
NINe.2
EuroSport-07
