Alternator help
Old 02-06-2011, 06:32 PM
Project66impala's Avatar
Default Alternator help
I got my Ls engine intalled and the alternator is low mount on the driver side.Is there a cheaper way to mount it high on the pass side?
Old 02-07-2011, 08:45 AM
rockytopper's Avatar
pm sent
Old 02-07-2011, 09:28 AM
1981TA's Avatar
You might try the corvette front drive system. Google search GM 19155067 and look for a listing that shows the included part numbers. I don't know what you've got already, but a good portion might interchange, so you might be able to get away just buying a bracket or two. Two caveats: It requires a Corvette balancer and I think the corvette alternator is slightly different in terms of where bolts line up.
Can anyone clarify?
There are aftermarket setups you can get as well.
Old 02-07-2011, 02:57 PM
camarof41_383's Avatar
Its not cheap but Speed Inc sells a kit to mount the alternator high on the passenger side.
