Build thread 2002 Z28
Figured I'd post up a build thread on here.
I bought my 2002 Camaro Z28 M6 in October 2009 from a good friend. The car had 32,xxx miles on the clock and now has 38,500 miles. Car was completely stock minus a few things:
LPP Stainless Steel Longtubes
LPP Stainless Steel Y Pipe
SLP Stainless Steel Dual Dual Catback
KYB AGX Struts and Shocks
Eiback Pro-Kit Springs
Suspension Techniques Swaybars (1 3/8th in. Front, 1 in. Rear) with Poly bushings and Endlinks
This is what I currently have:
Engine:
LS6 Intake
Texas Speed PRC Stage 1 LS6 heads w/ PRC dual springs .650 lift milled to 61cc
Patriot 7.4 hardened push rods
Patriot 225/229 .580/.590 114+4 LSA Cam
LS2 Timing Chain
Ported, Polished and bump stop modded stock throttle body
MTI Clear lid
LPP Stainless Steel Long Tubes
LPP Stainless Steel ORY (changing soon)
LPP Stainless Steel Resonator dumped before the axle (changing soon)
Suspension:
Strano Springs
Suspension Techniques Swaybars (1 3/8th in. Front, 1 in. Rear) with Poly Bushings and Endlinks
UMI Adjustable Lower Control Arms
UMI Lower Control Relocation Brackets
Transmission/Drivetrain:
Spec stage 2+ clutch
Tick Performance Billet Adjustable Master Cylinder
Pro 5.0 Shifter
Moser 12 bolt with 4.10 gears
Moser Differential Cover
PST 3.5" Aluminum Drive Shaft
Exterior:
Knock off Torque Thrust M replica's (really replica bullet wheels LOL)
Stock SS Spoiler
Engine:
LS6 Intake
LS2 Timing Chain
MTI Clear lid
Suspension:
Strano Springs
Pro 5.0 Shifter
Exterior:
Stock SS Spoiler
This Saturday I will be dropping my car off at American Racing headers for new headers and ory. I also will be receiving my TSP Rumbler 3" Catback this Friday which will also be put on when I drop the car off.
Just ordered UMI adjustable torque arm and UMI adjustable panhard bar.
Current parts waiting to go on:
PST 3.5" Aluminum driveshaft
UMI adjustable LCA's
LCA relocation brackets
Moser 12 bolt diff cover
UMI Torque Arm Relocation kit
Track run with true dual exhaust and stock 10 bolt:
Uploaded with ImageShack.us
Dyno graph with stock 10 bolt/ 3.42's and true duals:
Where are you located? I have lpp headers and ory just sitting in my shed now that I have arh stuff
Had i known about this build I woulda gladly let you borrow my garage and tools seeing that everything done to my car was done inside of it by me. And I'm not jealous of the power someone else built for you, Johnny poops.
