My CNC'd Brodix IK210's came into today, pics!!!!
Ordered these about four weeks ago, Brodix cut the heats for reverse coolant flow and cnc'd them in house. At a .650 lift they flow 285 intake and 222 exhaust.
Fixture type, bore size, material used, pressure, pipes/extensions, etc can all have a dramatic effect on the numbers the bench spits out.
Also keep in mind the fact that most claimed flow numbers are with the heads at the largest chamber size available, and that milling down the heads can significantly lower flow.
After a milling my AFRs I had my heads flowed (to spec a cam for them) and they peaked 7% lower then the claimed numbers released by a very reputable and trustworthy shop after their porting. All that 7% loss was not due to the .030(~5cc) milling - I'm sure a lot of it was just from being tested on a different bench, using a clay fixture, and no pipe.
I talked to brodix and i was thinking about getting the 221 Track1 heads which cnc'd flowed some stupid high numbers. But he said they were so big i would loose some bottom end power and he recomemded the IK210's cnc'd for my combo, regardless they will be tons better than my old untouched trickflow 195's.
On a 396, I bet those 221's would have rocked! I'm sure your car will still run great with the 210's though. You can sell off those TFS195's on here for $600-$700 assembled. They are perfect heads to send out to AI for their 215cc cnc package. Nice way to recoup some of the cost of the Brodix heads.
FWIW a set of 195cc heads on a 350 cube engine will behave very similar to a set of 220cc heads on a 396 all things being equal. Big cubes require bigger ports to support them. A 210cc port feeding 396 cubes is similar to 186cc port feeding a 350. Should make great power down low but not necessarily want to rev really high.
Do you run an auto or a T56?
