Wideband o2 datalogging
Old 02-08-2011, 12:13 AM
ByProxy's Avatar
Default Wideband o2 datalogging
how are you guys installing widebands and logging the rpm readings on these cars without going through the pcm? And if you aren't how are you tuning with the wideband without rpm datalogs? Thisis an lt1 car so no ls1 stuff please
Old 02-08-2011, 10:55 AM
Moderator
jimmyblue's Avatar
If you go with the Innovate LM-1 (-2, whatever) they
will be pleased to sell you auxiliary input gadgets that
can log RPM (spark clamp-on), MAP (tap the wire) and
so on. All goes into the meter, and you can download
it to PC. I bought a bunch of it for using on the Caprice
but haven't actually used it; the old girl just runs fine
and I haven't felt the need.
