PCM question
Old 02-08-2011, 03:13 AM
99ls1tj's Avatar
Default PCM question
For a 2000 LS1, do the a/t and m/t use the same pcm and os? thanks
Old 02-08-2011, 05:14 AM
TunerGuy's Avatar
They would use a differant tranny segment
09365896 PCM
9381344 OS
16264189 Tran cal Automatic
16264348 Trans Diag Cal automatic
16264290 Tran cal M6
16264349 Trans Diag Cal M6
Old 02-08-2011, 08:52 AM
Frost's Avatar
The engine cal segments end up being different between them as well. Most of it is airflow related, but still..
Old 02-09-2011, 01:40 PM
99ls1tj's Avatar
Thanks for the replies. I'm learning just enough to be dangerous. I'm actually using a compushift, but the PCM came from an a/t and was previously tuned by the previous owner for an a/t. Right now, I'm getting about 6 trans related codes. I have hp tuners, so I assume I can turn the codes off, but I'm really sure what to do about the tuning. Another problem is I see no way for the pcm to know what gear the tranny is in. Any suggestions? thanks
