where to find a good circuit box
Im going to be adding quite a few different electronic devices to my car, including but not limited to:
fuel pump 1 + relay
fuel pump 2 + relay
lingenfelter 2 step + relay
electronic boost controller
1000W amp (already installed but will be changing wiring)
bet on the Transbrake switch running through here once installed
my battery is in the T-top well, closest to the passenger side. I prefer to mount this box on .5" pedestals to the front wall of the well, just above the battery.
Id like a circuit box I can mount all this in, Ive got fused power distribution blocks (2) that have 6 terminals each that will be in it as well as the opposite ground blocks, and all three relays with room for more.
I figure 12 to 18 inches long, 8 to 12 inches wide, and 2 to 4 inches deep. Must have a lid, can be metal or plastic but I do not want transparent plastic. Ive been searching for a good two hours now but havent really come up with anything that seemed perfect. anybody have any ideas?
fuel pump 1 + relay
fuel pump 2 + relay
