Doesn't go into any gear, then move the car 2 feet forward and it goes into gear?
Engine running
Does not go into any gear at all.
Engine off
Doesn't go into gear, then I push the car 2 feet forward and it goes into 1st, 2nd, 3rd, and 4th gears.
Engine off
Sounds like your clutch isn't disengauging at all. What does the car do if you put in gear then try to start it? DO NOT TRY THIS IF THERE IS ANYTHING IN FRONT OF YOUR CAR!!! If the clutch is broken or the hydraulics are bad it will lurch forward into things. Also if there isn't anything in front of your car be prepaired to shut the car off if it does happen to start and roll away.
Ok. Try this, start the car and put the shifter in 1st gear and put pressure on it like you are trying to push it into gear. Then with your other hand shut the key off. If the shifter falls into gear then it is a clutch issue. Your 5th,6th and reverse could be a number if things. Try the 1st gear test for me and let me know.
With the engine off, the car doesn't go into gear. I applied pressure into 1st gear and then started the engine. It didn't go into gear. Then I turned the engine off and it went into 1st gear.
Sorry, I guess I could have worded it a little more clearly.
I ment, start the car, hold the clutch pedal in, then put pressure on the shifter like you are trying to shift into 1st gear, while keeping pressure on the shifter reach around with your other hand and shut the key off.
