Carbureted LSX forum - MSD 6010 What ignition timing chip should i be running?
Fastdriver1992
02-08-2011, 07:54 PM
i've been racing the car for almost 2 years now and i've been running the number 4 ignition timing chip and the car has been running good. i was wondering if i should start changing chips to try and get little better E/T out of the car. should i try and set my own timing? should i try different chips?
What chips r u guys using?
Thanks
Anthony
Z28/2002
02-08-2011, 10:01 PM
Do your own timing curves to get the most out of the setup
daschra79
02-08-2011, 10:42 PM
^^^x2
ZONES89RS
02-08-2011, 11:57 PM
Man, i went from the most aggressive chip, to my own tune, all i can say is it was night and day, a whole different car.
Should we say more?
We have a thread in here on recommended curves, or what we are each running anyway.
Fastdriver1992
02-09-2011, 10:07 AM
Ok thanks guy I'll have to play around with it at a track rental this year
boostdoctor
02-12-2011, 09:14 AM
I just bought a 6010 box used. Do i need a chip for this box to operate? I plan to program my own curve.
Z28/2002
02-12-2011, 11:19 AM
If you are going to use the software to make your own timing curve, you don't need the pills
rojs234
02-12-2011, 11:34 AM
If I remember correctly, the box will default to the curve that is produced by the #3 pill if you don't set a curve yourself or if you don't insert a timing pill. If you didn't get any paper work with the box you can go to MSD's web site and download the instructions which also include the specs for all the timing pills.
hifi875
02-12-2011, 02:38 PM
If you are running a map sensor and using one of the chips, does the msd box see the map sensor?
Z28/2002
02-12-2011, 03:26 PM
I think this is correct. Also if you set your own curve then put a pill in it, it reads the pill
Z284thgen
02-12-2011, 04:03 PM
mines only been on pill 1 as a base dyno and break in period
i know i made a curve and loaded it and seems a lot perkier and peppy havent been back to dyno to full on tune it yet thats coming late spring
rojs234
02-12-2011, 04:58 PM
The short answer is yes. If you have the MAP hooked up it will produce the vacuum advance curve that is specific to that # pill. Although most of the pills use a similar curve, there are slight differences. Again... the instructions show the advance curves and the individual vacuum curves for each number pill. The trick for most people is trying to convert MSD's PSIA numbers to the more familiar inches of vacuum. If you do a search, there is a coversion chart on here somewhere.
