3500 stall...
3500 stall...
If I put in a 3500 stall on a purely bolt on LS1 2000 Trans Am, how will it drive. I don't race it, but will it drive better with the bigger stall in it. It's just a drive on nice day car and it doesn't have a cam. All it has is a lid, P&P TB, K&N filter, LT's, Hi-Flow cats, and true duals w/ an X pipe and LM1's under the axle and out the back. Can someone please explain to me in detail exactly what this will do to my car as far as normal driving is concerned. I understand that it will allow me to "power brake" it up to 3500RPM's before the tires move, but like I said I don't race so what benefits would I get from one of these on my car as a normal street driver. Is it worth it? I MAY do a cam later but have not decided.
Restricted User
If your not going to put a bigger cam in then just put a 3k or 3200 stall. Dont ever go over 3500 for a daily driver. Make sure you tranny is good enough to put a new stall in.
Whys that?? I'm pretty sure it comes down to what the person can put up with on a daily basis..
Some people think 3500 is big, others think 3500 is on the smaller side..
I personally think the 3600-4000 area works good with for most peoples boltons and/or cammed LS1's.. But i'm a big stall lover.. go big or go home, haha.
the OP wasnt asking for a "fun Factor" but for it to drive netter, and with being basically stock it wouldnt drive better, but worse...so to say. Not disagreeing with you, it would definently wake the car up and be tons more fun to drive. Just trying to answer the OP as best as possible
you put a 3500 stall in,you might like it so much that you might not want to put a cam in.
you didn't state what gears you have.
with 2.73s,the rpm necessary to get the car moving will be annoying in the beginning and you might get used to it,3.23s' won't be as 'bad',3.73s' even better.
My first 3 mods that I recommend are:
Sticky tires
Converter
Nitrous
If you don't want to go fast from a dead stop and you don't want to get some good sticky tires... don't do a converter. What it does is make your car feel like it has 100 more HP when you take off, unless you have crappy tires, than you will be able to spin your tires at will from a dead stop. Usually its worth a half second reduction in quarter mile times. Or 5 car lengths roughly..
My opinion, its a better mod than all that you have done so far.
I enjoy driving a 4500 stall but feel that 5000 is a bit much.
Sticky tires
Converter
Nitrous
Sticky tires
Converter
Nitrous
Sticky tires
Converter
Nitrous
Since you are asking an opinion question, ....
In my 'opinion', ..., It won't effect it.
It will still move when you press the gas pedal.
But I can almost gaurantee, you'll get that damn leadfoot syndrome rather quickly.
Yes, you may lose some minimal mpg even if you drive it exactly as you had before.
You seem to be looking for justification to do it, to maybe NOT do it.
No one else can answer your opinion question.
Do it. If you don't like it, un-do it.
I did it, & will never look back, ..., but will eventually look forward to a higher rom converter one of these days.
