horible vibration
horible vibration
at about 4 thousand rpms it gets a horrible vibration wether im in nutural or in gear(less noticable when in gear). at first i thought the engine was starving for fuel because i thought the injectors were cloged up(car sat for five months only getting started once a week) so i just changed them out today and its still makeing a horrible vibration. also the motor mounts are fine but im starting to think it might have something to do with the clutch cuz i got it replaced about two months ago. what do you guys think
Village Troll
there is no balancer on an LT1 car, its a dampaner. Im putting my money on the flywheel. Did you have it replaced? The crank shafts in these cars are balanced nuetrel in the front and by the flywheel in the back. Some more info would be great!
lol i had a shop replace every thing clutch pressure plate flywheel and im starting to suspect the shop because i had them replace the master and slave cylinder while they were working on it and i bled the brakes when i changed the pads and there was more air than fluid in the lines. i geuss thats what happens when you take it to a small shop. but what would be wrong with the flywheel/clutch in particular
Village Troll
Village Troll
Depends on your abilities. It's not really difficult per se if you have the correct means to remove it. If you do a search I'm sure there's a write up somewhere on how to remove the trans.
would the transmount make any sense if its doing it when im in neutural. and i sure hope it is the trans mount i dont wana have to drop the tranny. sounds like a nightmare
