Pontiac GTO 2004-2006 The Modern Goat
Cat removal.
Old 02-10-2011, 08:49 AM
youngbuck's Avatar
Default Cat removal.
will cutting my cats off an straight piping it cause me any problems other then throwing a code? Stock tune. And I'm leaving the stock mufflers.
Old 02-10-2011, 01:31 PM
Scolmoo's Avatar
Other than being illegal probably not. You also will not gain anything either maybe 2hp. Switch out the mids to JBA or just get headers with catless mids if that is what your going for.
Old 02-10-2011, 01:55 PM
youngbuck's Avatar
No emissions here . Just didn't kno if it will make it run rich an foul out the plugs our anything. Doing it cheap for now an make it a little louder in the process.
Old 02-10-2011, 04:05 PM
FryZ71's Avatar
If you want it louder, just switch out the muffs or do a muff. delete...then you don't have to dick around with the CEL light.
Old 02-10-2011, 04:24 PM
youngbuck's Avatar
trying not to spend any extra cash right now, I just wanted to kno if it will make it run bad or hurt anything.
Old 02-10-2011, 04:36 PM
codysgto's Avatar
It will throw rear o2 senor codes.
Old 02-10-2011, 05:29 PM
RedHotG8's Avatar
Removing the cats will hardly change the sound, you have to change or remove the mufflers to get a noticeable sound difference.
Old 02-10-2011, 05:33 PM
FryZ71's Avatar
Straightpiping cats = straightpiping mufflers, $$-wise...it's just pipe.
Like the RHG8 said, a muffler delete will change the sound alot more than a cat delete.
Old 02-11-2011, 12:34 AM
RedfoxGTO's Avatar
I have headers with catless mids and it throws my check engine light.
Old 02-11-2011, 01:35 AM
impulsegoat's Avatar
im running LT's catless mids and i dont have any check engine light. Of course i have a dyno tune which he might have tuned out the 02's but not sure. Mine is cammed, catless, and muffler delete and everyone goes crazy when they hear my car idle. It's fun roaring at mustangs and scaring the **** out of them
Old 02-11-2011, 11:30 AM
twinturbo496's Avatar
By 2004 GM factory cats had improved dramatically from what was installed back in the 80's, for a stock displacement, stock cam, etc the cats aren't much of a limit. Without some tuning after the removal, it will probably make less power.
If you want to go fast for cheap, the answer is in a blue bottle..
Old 02-14-2011, 04:01 PM
RE AND CHERYL's Avatar
Prety sure he does not care to go fast, just sound like he can.
Re'
Quick Reply: Cat removal.
