LS1 combustion chamber/piston question
Old 02-10-2011, 10:57 AM
jgebhardt's Avatar
Default LS1 combustion chamber/piston question
I am building a new LS1 for my 98 Trans Am. I am using Trick Flow GenX 220 heads with a 64cc combustion chamber. I want the compression to be at or a little above 11:1. What type piston do I need? Dished, flat or dome? Also what type are the stock ones and what is the combustion chamber size on the stock heads? Any help or advice would be appreciated.
Old 02-10-2011, 01:37 PM
Closed ex-Sponsor Account
Jon@HKE's Avatar
With the stock (flat top) pistons you will be around 10.7:1 with .052 head gasket. You need a slight dome or mill the heads to achieve the compression you want.
The stock heads are 66cc~.
Old 02-10-2011, 02:32 PM
jgebhardt's Avatar
Default ??
the heads I am loong at are 64cc being 2cc smaller wouldn't get me there?
Old 02-12-2011, 06:39 PM
jgebhardt's Avatar
Still looking for more info on this.
Old 02-12-2011, 08:50 PM
trans_am7935's Avatar
for example i am using PRC 5.3 heads with a 1cc mill for a 61cc chamber and the .040 MLS head gasket, i am gonna be just at 11:1 with the stock flat top pistons
Quick Reply: LS1 combustion chamber/piston question
