Those LS-Mustang guys running F-body Radiators, PLLEEEAAASSEE HELP!
So I am getting to the final steps and have a couple of questions. Obviously upper radiator hose goes to upper port on radiator, lower to lower.
1- There is an additional output on the driver side of the radiator, where does this go?
2- The steam coolant pipe, where does this connect into?
3- he two ports on the bottom of the throttle body, are these vacuum or are these supposed to be for coolant?
4- For an overflow do I just route the very top outlet (closest to the radiator cap) into an overflow tank?
Thanks!
Thanks!
Thanks!
Thanks!
2- that should be below the radiator cap
3- should also be coolant
4- yes
do you have a pic of the back side of radiator to post so we can see this port on DS
Sounds like you have a LT1 Radiator..cap it.
Barb below the Over Flow Barb, under the Radiator Cap.
3- The two ports on the bottom of the throttle body, are these vacuum or are these supposed to be for coolant?
Dont worry about them.
Yes.
Thanks!
Yes.
Thanks!
