Small Block & Big Block Chevy Specific - cam ?s
View Full Version : cam ?s
Tim01Z
02-10-2011, 01:55 PM
i have a 97 350 vortec with the iron heads that are getting bigger valves i need help deciding a decent cam for this setup; edelbrock performer rpm intake iron heads going with 2.02 int. and 1.60 exh valves 4.10s out back its a 5 speed car as well anysugestions
87silverbullet
02-10-2011, 09:05 PM
I hope they are getting a spring change and milling down the valve guide as well. Look at the Extreme energy line from Comp. They have worked well in the past and make sure you look at the hydraulic roller line and not flat tappet since you have a roller block.
Tim01Z
02-12-2011, 05:27 PM
Yes the heads are being done the right way and I knew it was a roller block just didst know wT kind of specs to b lookin for I'm aiming for high 7s in the 1/8th the car went 8.80 spinning on street tires all the way if any of you guys know a better way to achieve this goal plz fill me in
87silverbullet
02-13-2011, 02:06 PM
Here is a 440 hp build with vortec heads and here is the article.
http://www.carcraft.com/techarticles/116_0209_vortec_small_block_engine/index.html
They used a flat tappet cam because it was a 2 piece rear main seal block but here is the cam they used in a roller set-up from comp.
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=08-432-8&Category_Code=RLERCAMXE
That should make the performance you need to obtain your goals.
01 WS6 6.0
02-13-2011, 10:34 PM
I've got a SBC crower OE roller cam set up with the roller lifters and engine pro pushrods all brand new PM me if interested the cam is 00469s
ZONES89RS
02-14-2011, 03:40 AM
Ive notice majority high end power high TQ vortec builds have cams around 230/236 duration and just over .500 lift on a 110 LSA carbed, so get something along that line and it should perform as well as it can.
87silverbullet
02-14-2011, 02:51 PM
Thats the exact specs of the cam I posted from Comp.
01 WS6 6.0
02-14-2011, 10:34 PM
http://www.crower.com/searchresults/
Heres mine
raceman14
03-01-2011, 09:38 PM
Our custom cam runs in a lot of oval track GM604 crates where tracks do not pull engines down. It is 235*@.050 & .510" lift 110LS ( Int. C/L installation varies on where you want the torque ), Outlaw valve springs 135# seat, and Alien custom built hydraulic roller lifters ( our house stuff ). Our cam lobes are way different than any bodu elses by being big at .100", /200" and .300" where the intake flow really need help off the seat...and we cam doctor them after grinding to make sure they are right on every time. If you want a little more out of the engine you just run 1.6 or 1.65 rockers.
There is not another Hydraulic roller lifter on the market that has been developed on the SPINTRON for hi-rpm use. We turn our oval track stuff all day long at 7500rpm and like I said it lasts a season or more with proper oil changes and valve lash checking.
Our valvetrain package hits so hard it sounds like the engine has 16:1compression.
With 10:1 CR Fastburn heads this makes 475 RWHP and turns 7500 for at least a full season of racing and sometimes two seasons. Hit me thru e-mail for additional info.
I have been running my own chassis dyno 12 hours a day for 25 years and have tested just about everything known to man. You might want to reconsider the intake as that dual plane does not like running much over 6000RPM.
I am getting a couple pieces ready to run at Commerce, maybe I'll see you there.
78z
03-01-2011, 10:51 PM
i have a 406 with a roller cam, it is a comp cams 230-236,510-520,on a 110 it also has cast iron heads 202-160, it is n a 78 camaro i have stock gears 342. it ran 11.82 on the motor and 10.90 on a 100 shot u can see the video on utube type n jesse hunt 10.90 i love this cam. I think u will to. just thought i could help good luck
78z
03-01-2011, 11:00 PM
i have the same cam n my car i love the way it pulls
