Houston area shop for ls1 electrical problems?
Old 02-10-2011, 04:36 PM
DJstylze's Avatar
Default Houston area shop for ls1 electrical problems?
Guys - first thanks for reading.
I've got my brother's 98 z28 throwing 2 codes P0803/P0102.
Narrowed it down to either a bad wiring harness or perhaps bad connections?
Keeps blowing the ENG fuse. (reverse is locked out - already swapped the reverse lockout solenoid)
Anyways, I tried dealing with Craigslist mobile mechanics - nightmare. No one would even show up.
I'm trying to find someone who is knowledgeable about LS1's so this problem won't be a learning class.
I'm in Houston - please let me know.
Thanks
Mike
msb6807@yahoo.com
P0102 Diagram and details
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
http://www.gearchatter.com/viewtopic8767.php
P0803 Diagram and details
DTC P0803 Skip Shift Solenoid Control Circuit
http://www.gearchatter.com/viewtopic8681.php
Old 02-10-2011, 10:52 PM
5w20's Avatar
what side of town are you located?
Old 02-10-2011, 11:31 PM
DopeFedZ's Avatar
Follow the wires for the O2 sensors make sure the wires are not cut or frayed and touching up against anything metal.
Old 02-11-2011, 07:28 AM
DJstylze's Avatar
I'm on the southeast side - but I'm willing to drive around to get an experienced mechanic.
I've already been up and the down the bottom of the car. I pulled the wires out of the hose and everything looks good. I don't have headers either.
I'll double check each O2 sensor again - seems to be the common problem but again, those guys had LT headers installed.
Thanks for the replies though.
Old 02-11-2011, 07:46 AM
blk90coupe's Avatar
Gforce
Old 02-11-2011, 08:10 AM
Destroyer of Exotics
FlashWS6's Avatar
Originally Posted by blk90coupe
Gforce
yup, there wiring guru Greg can find the problem.
Old 02-11-2011, 11:50 AM
DJstylze's Avatar
To my knowledge performance shop labor rivals dealer pricing.. the car is a basic z28, not some of these h/c/fi cars I see on here. If I'm wrong, someone correct me.
I can give Greg a call and see what he's looking at for his time nonetheless.
Your help is greatly appreciated. Thanks.
Old 02-11-2011, 12:51 PM
Bad Chad's Avatar
To be Honest it may be cheaper to just buy a harness for $100.00 and Install it. If you take it to a shop that charges 100+ and hour and they spend all day looking for the problem you will have a healthy bill.
It will take about an hour or 2 to swap a harness
Old 02-11-2011, 03:16 PM
DJstylze's Avatar
I really considered that option - problem is where can I buy an harness for 100 dollars?
Old 02-11-2011, 03:17 PM
Bad Chad's Avatar
I've seen them on here and Craigslist from $100.00 - $150.00
If your car is an auto make sure you buy an auto harness
Old 02-11-2011, 05:03 PM
DJstylze's Avatar
Ok, ebay's pricing was absurd.
I'll throw a post on the for sale section. It is a 6spd so thanks for update.
