tremec part numbers for MN12 T56 gears
Does anyone know the OEM part numbers (GM or Tremec) for the gears in the GTO MN12 T-56? I've had a little issue with a gear set I ordered from Tick (who drop ships parts from D&D). This last issue is that the 3rd gear they sent me is .055 bigger overall OD than the one originally in my trans. It's the same number of teeth, appears to be the same part, but literally cannot put the assembly into the case with this new 3rd gear. We pushed it off, put the original 3rd gear back on, goes right together (this by process of elimination trading other original parts). Needless to say, I'm frustrated. My trans builder is whacking me with a couple extra hours of labor for all this run around too, so I'm extra pissed about the situation.
Anyway, vent over, but I still don't have a trans together, and between Tick and D&D, they have been unable to deliver the parts I ordered. If someone can tell me the correct part identification, I'll go straight to Tremec to get what I need.
Thanks in advance,
TJ
Thanks in advance,
TJ
Thanks in advance,
TJ
Thanks in advance,
TJ
