cam timing issue
cam timing issue
a friend of mine put a lsx block in his car and it will fire up then die right after. the car is throwing a po343 code and we changed the cam sensor and still no luck i havent checked voltage but will tommorow. my question is when running the lsx block do you run the half moon cam gear or the 4x cam gear?
