Vibration issue...
Vibration issue...
Hi I just got a 1998 camaro z28, I have an issue with it though. Its an LS1/A4 car, every time the car is under WOT the car vibrates, and when I am cruising at 70 mph plus, I read a couple of threads, and heard that if you put it in neutral and it go in WOT while at a cruising speed of 70 mph and it vibrates it can be the drive shaft. That is what happens to my car too. Any help would be appreciated.
Probably a bad U-Joint like stated before. I would take your drive shaft out, take it to a driveshaft shop and have them put new u-joints in and balance the whole assembly. That way you know its done right.
Yeah U joint on that one! Mine has the long tubes that seem to rub and vibrate the car i gotta pull em out and dent em up a bit and check what kind they are so i know never to buy em again lol!
