Buy slave cylinder or not?
A little backround. I currently have a LS6 clutch. Pedal sticks to the floor. Did the drill mod and DOT 4 fluid. Still happens. I do know my clutch is worn so it could be the PP.
I am upgrading to a Centerforce twin disk right now and while it was apart should I replace the slave or will the clutch fix my probem finally? Or does anyone reccomend to get an aftermarket slave to run that clutch? If so which one is the best?
I am also considering changing the Master but I feel maybe my stock driled one will be alright.
Any input is appreciated. Thanks.
I do have low miles. I am confident now that the weak link is the slave cylinder. I can easily access the master cylinder if the problem still persists. Easier than the slave cylinder anyways.
