Western Members CA, AZ, NV, UT, CO, NM, HI
Rev limiter help....
Old 02-13-2011, 12:19 PM
nissan owner's Avatar
Default Rev limiter help....
For some reason my car's rev limit is at 6500 (give or take) and my car is completely stock. I just got my car, I don't know if the previous owner had it tuned like that or what not, but after 6200 or so, it feels like my car just dies out of course because its stock.
Can anyone help me lower the rev limit to stock or how much does that cost to do? I don't want to tune it right now because its stock, and I do plan on putting mods, so i'll rather wait to tune it after, I just need the rev limiter to be drop to stock.
Thanks in advance.
Old 02-13-2011, 01:02 PM
djsanchez2's Avatar
Why not just shift at 6k? What harm could it do to leave it as is?
Old 02-13-2011, 03:31 PM
True, but since its an automatic, I believe its a lot better if the PCM controls the shifts, I could be wrong...I guess i forgot to mention that its an A4.
Old 02-13-2011, 03:54 PM
ZexGX's Avatar
Pffft, just throw in some hardened pushrods and stronger springs.
Old 02-13-2011, 03:58 PM
180ls1's Avatar
ya you might want to get that changed, considering a stock cam car makes peak power at 5200 or so. You will have to get it tuned to change that or have someone with HP tuners change it. Im sure one of our sponsors can take care of that for you.
Old 02-13-2011, 06:33 PM
6spdchevy's Avatar
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
you might wana check this thread out he wants to raise the limiter u want to lower it same process which is a tune https://ls1tech.com/forums/western-m...-will-pay.html
Old 02-13-2011, 07:58 PM
topfig1's Avatar
If you are not planning on major mods, pick up a hypertech hand tuner and do it yourself. If I remember correctly, I found one for 125.00 for my old TA. When the car was totaled, I put the PCM back to stock and sold it for 150.00 Good luck
Angel
Old 02-13-2011, 08:17 PM
180ls1's Avatar
Angel
a better option might be to contact "FROST" he does the mail order tuning on these cars and has done hundreds if not thousands. Here is the link and you probably wont get a better tune unless you put it on a dyno, cost is $150. He is also a sponsor here with many happy customers.
http://www.tunedbyfrost.com/services2.htm
Old 02-13-2011, 08:32 PM
Thanks guys, I might just have to take it easy until I get some more bolt ons, then fully tune it.
Old 02-13-2011, 10:16 PM
topfig1's Avatar
Well don't over rev the stock engine too much. I would still try to find a hypertech or similar unit. Plug it in, turn the key and follow instr. Five minute fix. You won't have to remove ur PCM and have your car down until you get it back.
