how can you tell 06-07 diff???
The part number is on the right side, rear of the diff.
You can not see it by looking, but you can if you use a mirror & flashlight.
It is possible to hold a small camera at the correct angle and take a picture.
1st Gen. # 10361308 --- '04 & some '05s
2nd ---- # 10368780 --- mostly '05
3rd ---- # 157937556 -- all '06-'07
4th ---- # 25873498 --- was not released til 2008 and is the replacement for all V1s
>This is not to be confused with the total redesigned cradle & rear of '08 to present CTS.
1st Gen. # 10361308 --- some '04
2nd ---- # 12378261 --- mostly '04-'05
Found the numbers on a spare rear it reads;
10368780 ???
any info on this
BobH
Can you take a non V case 06-07 and put the V guts in it and accomplish the same thing??
157XXXX or 258XXXX case, with V internals. Yes or no? Lol
Read this.
https://ls1tech.com/forums/cadillac-...struction.html
Opps!
Thanks for posting your part number.
You in fact have a 2nd Gen rear.
I need to edit my post.
My search indicates that I posted an incorrect part#. I got those part numbers from a previous discussion, but evidently that part number appears to be an old part number for the gear lube.
Opps!
Opps!
Thanks
BobH
There is a guy on this forum that was going to do that.
Read this.
Read this.
