VE pid in EFILive 6.3
Possibly... you should check a couple of things first. Make sure the PID is using the correct displacement for your engine - I think 346ci is the default value. If your different you need to edit the calcpids file.
EFILive reports %VE, but the tables in Edit use %VE*30. (So 100% VE = 3000 Edit units, 50% VE = 1500 Edit, etc.)
