Pontiac GTO 2004-2006 The Modern Goat
8 Second IRS Goat
Old 02-15-2011, 11:32 AM
N2OBaby's Avatar
Thumbs up 8 Second IRS Goat
I just got my subscription to GMHTP.
There is an '05 Goat with a 427 Warhawk block with a F1-R Procharger runn'n 8 seconds(1/4).
Any of Ya'll seen this car or know the owner?
Old 02-15-2011, 11:39 AM
CamaroAl's Avatar
His screenname on LS1GTO is T-Bones Goat, I seen the car 2 years ago down at the east coast shoutout he puts on at darlington dragway in SC the car is bad ***
Old 02-15-2011, 01:34 PM
N2OBaby's Avatar
Thumbs up
Kool Thanxs!
Would love to see him hit the Quarter with that Beast!
Old 02-15-2011, 02:54 PM
impulsegoat's Avatar
Ya that would be insane to see that thing make a pass
Old 02-16-2011, 01:57 PM
N2OBaby's Avatar
Lightbulb
What shocks me is the stock IRS and a 8.8 inch axle can survive an F1-R Procharged 427.
He blew an LS7 427 earlier.
Old 02-16-2011, 08:46 PM
CamaroAl's Avatar
You guys need to go down to the east coast shootout in November it a great time and some really bad IRS cars show up
Old 02-16-2011, 09:31 PM
T-Bones Goat's Avatar
Thanks Al and thanks for the props guys. I was honored and thrilled to be in GM Hightech. There was alot of info left out in the article so if you are wondering anything about the car feel free to ask. The East Coast Shootout IV will be November 12th.
Old 02-16-2011, 10:20 PM
LEO
LEO's Avatar
That is one incredible GTO.
Old 02-19-2011, 02:18 AM
Ya i would like to come out and see some of these cars in person. Where is the event held??
Old 02-19-2011, 06:30 AM
Darlington Dragway in Hartsville SC You can check the schedule at darlingtondragway.com
Old 02-19-2011, 06:47 AM
JoeyD's Avatar
Definitely come on out to Darlington. Not only is Travis' GTO bad ***, but he puts on a great event as well.
Old 02-19-2011, 09:06 AM
05raptorle's Avatar
narrowed rearend it said in the mag? I'd like to see some pictures of what you did to narrow it.
Old 02-21-2011, 06:32 AM
Canada's Avatar
You running the th400 behind it or the 4l80? I for some reason can not remember. Is notching the fender for the f1-r and f1-c that bad? Looking at both for when I do my 427 but I knew the fender must be notched.
Old 02-21-2011, 11:28 AM
tom's2005gto's Avatar
he is running the 4L80E
Old 02-21-2011, 01:39 PM
LS1 Melly's Avatar
Wow!!
Old 02-21-2011, 10:20 PM
Scott Grant narrowed the rear in order to fit a 28x10.5/15 tire UNDER the rear. He cut the ends of the control arms and welded them back removing material from both sides. The axles also had to be shortened. Scott is the head fabricator for the 48 and 88 cars in the Nascar series. He was the mastermind behind the rear setup. He actually built my setup for his own GTO originally.
As Tom stated I am running the 4l80e from RPM. Notching the fender is not that bad. Eric Yost did mine and from the looks of it, it wouldn't be hard if you have any sheetmetal experience. You will need to relocate the computer but it's not that bad.
Thanks alot Joey. I'm looking forward to this years event!!
Old 02-23-2011, 05:10 AM
Canada's Avatar
My dad works with sheetmetal everyday building airplanes so that probably wouldn't be much of a deal. Where did you end up putting the ECU at? Would look a lot better out of there anyway along with it allowing you to run the f1-r.
Old 02-24-2011, 12:31 PM
N2OBaby's Avatar
Question
Would you need mini-tubbs to run either 27X15X10.5,28X15X12.5,or 30X15X12.5 M/T ET Streets?
Old 02-25-2011, 08:09 AM
I will take a picture when I get a chance. It is basically on the side of the fender instead of the top. I then put a piece of nasa heat shield on it to protect it from the header.
Old 03-01-2011, 01:03 PM
newschool72's Avatar
hey t-bone...were u at the pinks all out in commerce, ga 2 or 3 years ago ? i talked to a guy that had a goat there that looked alot like your. it was running 9.60 s with a procharged 427.
Quick Reply: 8 Second IRS Goat
