Front springs to comp for ls1 weight
what springs is everyone using to compensate for the weight reduction of going from cast iron to ls1 al? I tried a search and came up with nada. I`m sure this has been discussed. sorry to rehash but my 67 camaro front end is going togather and i need to move forward
thanx
thanx
I used the Hotchkiss lowering. The advertisement promises a 'firm', but not harsh ride. These words would be applied to the iron block, I presume.
So, for the LS1, it'll prob be a hard ride.
I kept the old well-worn stock springs just in case the Hotchkiss are too hard.
A bit of cutting might be in order.
That sucks. I haven't gotten mine on the road yet and was hoping it would still ride good. Maybe I should cut the stock coils
I debated this also and ended up with the hotchkis lowering springs. I can not comment on the ride quality but I'm hoping for a "firm but not too stiff" ride since I'm also going to use their re-valved shocks. David Pozzi has good info on Moog springs which was is my Plan B if the Hotchkis are too stiff. Sounds like I'll be cutting my hotchkis springs to get it to sit right. A third option is the AFCO adjusters and short coil springs offered in various spring rates. I'll look around for PNs on all this and re-post.
BCZee, Can you comment on ride quality? Thanks...
