Car issues : Need help!
Old 02-15-2011, 12:30 PM
r0llz1104's Avatar
Default Car issues : Need help!
Have a huge problem,
I own a 1993 camaro z28 with lt1 engine. Recently i installed .270 cam, replaced hydrolic lifters, crane gold rockers 1.6 and long tube headers. Ever since i did this and the purchase of a tunned chip from pcm4less.com, my car began to give me a problem. Car idles great. But, thing is at every stop it turns off completely. My mechanic told me he discovered i had been running the car with an incorrect installed chip and that the cause might be a burned out ECM. Reason, states its not scanning any troubleshooting codes and concerned to know why Check Engine light on. We have already exausted all our resources. Before I purchase a new ECM, Stock Prom and reburn chip....We cry out for help! We ask for options or recommendations...thanx!
Old 02-15-2011, 01:25 PM
mguidry629's Avatar
Does it bog down and kill because of low rpm's or does it just kill abruptly, like some turned off the ignition?
Any more specs on the cam?
Old 02-15-2011, 03:09 PM
05HD's Avatar
Someone had the exact same problem just the other day- https://ls1tech.com/forums/lt1-lt4-m...le-issues.html
It was you! LOL. Did you try what ramair95ta said?
Did you try to reinstall the PROM properly?
Old 02-15-2011, 03:49 PM
qc97z's Avatar
Almost sounds like a poorly-written Nigerian scam ad on Craigslist.
So it has a .270 cam eh? Gotta love that half-stock lift.
Old 02-16-2011, 01:07 PM
r0llz1104's Avatar
mguidry629 : well its not because of low rpm's. It just kill abruptly, like some turned off the ignition?
Specs : Engine
Intake Manifold Ported LT1
Camshaft Specs : hydraulic roller lt1 270 camshaft
Duration .218 degrees , .224 degrees
Lift .495 lift, .502 lift
Old 02-16-2011, 02:53 PM
r0llz1104's Avatar
05HD : yes, we did that..but, problem not resolved.
Old 02-16-2011, 03:17 PM
mguidry629's Avatar
So the SES light is on, but it's not giving you any codes? If you jump the 2 OBD terminals, the SES light should flash. I think if it flashes 12, then everything is normal, but it will give you a code of some sort (I think).
With that cam, I think your car would run fine on the stock tune/ecm. Obviously, you can get more out of it, but it should run normal enough to drive it. Since all this started with the PCMforless PROM, then I say go back to stock PROM/chip and see what happens. I personally don't know much about PROMs and chips tuning since my pcm is a 95.
Keep us updated.
Old 02-16-2011, 04:56 PM
r0llz1104's Avatar
mguidry629: That is similar to what i was recommended on doing. if it flashes 12 does that mean that its not a ECM issue? if so, what might be the problem?
Old 02-17-2011, 01:02 AM
kagtech's Avatar
In order to fix your problem you have to at least take your engine back to a last know good state.
Use the Chip prior to the upgraded Chip.
Was beating my head on an issue such as this with a 1991 Camaro Z28 and it turned out to be Injectors (Rich condition) and the PCM (unable to read).
Replaced the PCM, then tuned for my setup.
Get a PCM in there that can be read first. Then troubleshooting of this problem can continue from there.
Here is a guide to your symptoms:
http://auto-repair-help.com/auto_dia...celeration.php
Old 02-17-2011, 06:36 AM
lt1-xjs's Avatar
If you just added long tubes you may need heated o2's.
