Help with dead spot
Help with dead spot
Just like the title says. About 2200-2600 rpms i can feel a dead spot. Like something is holding the car back a little. I've received my headers and will b doin the install in a few weeks which will include !EGR, !AIR, true Duals, spark plugs, wires, and a fuel filter. I'm
Hoping one of those takes care of the problem. Other than that I'm not sure what would b causing it. I'm assuming fuel or ignition. Thanks for the help.
Car has SLP Lid which needs to be replaced. Previous owner dropped something on it and broke it. Now thes a big retabgular hole cut in the front of it. And that's the only mod it has.
I'm goin to out some fuel injector cleaner in it tonight also. Thanks again.
SeaFoam is great for the fuel system. I do it every 3-4 months as maintenance. But you should change the fuel filter after that tank of gas runs out......in case any dirt was loosened and went into the fuel filter. Its a 5 minute job and $12.00.
So you want him to seafoam to clean the injectors, yet you admit the trash gets caught in the fuel filter which is before the injectors???...... You should go work for seafoam.
Found a vacuum leak right after the TB on the passenger side of the intake manifold. It's a decent sized hose the runs Down the side of the intake. Not sure where it goes. It was dark out and I could hear it hissing. Think that could cause a dead spot. My car idles high sometimes to. I'm assuming due to that leak.
Tell me you really do understand that process......you can't be that ****** airheaded edit..........
Uh, yea...SeaFoam can loosen large pieces of **** in the gas tank, the fuel filter will catch it though. But the SeaFoam will still go throguh the lines and clean the injectors.
Pitch em on the GPS locator too. Are you a salesman? Seriously.
Talk about digging a hole.........you must read and comprehend....comprehending being the important part.
Put the shovel down.
Annnnnyyyyy way. Can I just replace that pcv line with vacuum
Hose? It looks molded to me. I'm assuming the dealer would carry it or at least order it for me. I think Imma do my header install this weekend so everything is Gettin replaced. Plugs, wires, fuel filter, pullin off the AIR and plugging the EGR. so hopefully that dead spot will be dead Muahahaha.
Or you can get used factory lines "usually" at http://www.tacreationsusa.com/
He has a ton of good used stuff at good prices.
I'm getting the same thing, and though that since it is at the spot in the rev range every time that it might be an ignition issue. I don't really know a lot about ignition on things without distributors (I became a mechanic on a BBC), but that seems plausible to me. Let me know if this fixes your problem, because if so it will save me a lot of headache.
