question about slick size
i just bought some used 15' convo pros with 28x10.5x15 ET drags. the tires are taller than what i was planning on running, but i got a really good deal on these so i went for it. after i add a 12-bolt and a 150 wet shot, will this size be ok to run, ro should i get shorter tires next time i need new slicks? thanks...
Last year. Stock engine, cam, heads. 12-bolt, 4.30. M6. Used 26" on engine only; 28" on 100 shot. 1.64 on engine; 1.50 on the 100 shot.
With this years' set-up - head/cam the works, I'll be doing at least 150 shot stock bottom end. With stifting at 6500-6600 rpm's I am hoping the 28" will still work.
Keep your 28". You'll be fine with either 4.10 or 4.30. If street/strip go with the 4.10.
David
David
Originally Posted by FEAR THE LS1
It depends on the gears you get in your 12 bolt and is your car a Auto or manual?
Are those the wheels/tires F1 Dave was selling?
Lee
Lee
ok, so when i get my 12-bolt ill just go with 4.11 gears and i should be alright then? by the way, the car is a 6-speed. thanks for the input, guys!
