how to wire gauges?
how to wire gauges?
ok i'm getting some autometer gauges. I'm thinking water temp, trans temp and oil temp. or Fuel pressure. i can get them grounded and run power to them no problem, but what wire do i tap into for the sending unit? do i need to tap into the block or what is the deal here?
For water temp. I taped into the port on the passenger side head( w/ sender and adapter)
For trans temp on the autos there is a small plug near the top of the tranny -simply rempve plug and screw in teh autometer sender.
Oil temp I believe you use an adapter on the oil filter etc.
^ Exactly what he said.
Here's two links for the trans temp. I have the exact gauge thats shown in the first link, it's an Autometer Phantom 2 5/8" trans temp gauge (electrical) with sending unit for $45 shipped if you want it, figured I could save you some bucks.
Anyway here!
http://www.black98.cz28.com/photo6.html
http://xse.com/leres/ss/gaugepod.html
Anyway here!
wow thanks for the write up. I do'nt know about this though cause i'm not comfortable drilling and tapping into anything. i was hoping i could just splice off of some wires to do it. I guess i'm mainly going for looks too but. what are the 3 easiest ones to install? Oil temp?
Sounds like if you're going for looks and ease of install,
Water Temp
Trans Temp
Voltmeter
Voltmeter will literally be tapping into a 12v wire. For the other two you're just running a couple wires through the firewall, covering in wire loom and zip tying to whatever the hell you find around it.
Water Temp
Trans Temp
Voltmeter
