just some shtuff
just some shtuff
well first off just wanted to say ebay headers and y suck and i would not ever buy them. and 2nd i was justt curiouse how my car will run with no egr, air system? also is it better to have o2's even when the car is gonna be tuned or could i ditch them and be fine after its tuned??
The car will run fine without AIR and EGR albeit with increased emissions. Just make sure you have the EGR programmed out and leave the O2s and wiring intact.
When you buy the eBay long tubes, you should accept the fact that they are going to need some minor modifications to get to work. If you're not capable of making the necessary adjustments then maybe they aren't for you.
i dont know what the pump fuse is ?
