Loose shift stick?
Old 02-16-2011, 11:04 PM
BFarrier's Avatar
Default Loose shift stick?
so the car has 70,000 miles on it now and when in gear there is alot of play like something has worn out but dont know what it may be any ideas? has anyone experianced this before? when i an in gear it use to be really stiff and felt soild, now it has alot of play side to side and back and forth while in gear a good half inch play. stock shifter with hurst leather handle. going to be putting a short shifter in once i find out what the problem maybe.... thanks
Old 02-16-2011, 11:56 PM
jmd
jmd's Avatar
A thread about the part that is commonly suspect: https://ls1tech.com/forums/manual-tr...ttle-part.html
It's just under your shifter.
Old 02-17-2011, 12:06 AM
heymoej's Avatar
i have actually had the bolts come lose on my 2000.....just a thought,if you had not checked them.
Old 02-17-2011, 12:21 AM
BFarrier's Avatar
yeah i just pulled the center coNsole and it was the freakin bolts so i put some blue lock tight on them and its much better now.... anyone have suggestions for a good short throw shifter and stick? trying to keep it low and quick
Old 02-17-2011, 01:37 AM
cowboysfan's Avatar
http://www.ws6project.com/user_stor/...oducts_id=1176. this is what i have!!!
Old 02-17-2011, 12:14 PM
Save the manuals!
wssix99's Avatar
The lock-tite works but was a PITA for me when I had to remove the stick. I went to Nord Lock washers: http://www.nord-lock.com/ which also do the job with no mess.
Old 02-18-2011, 02:33 AM
BFarrier's Avatar
Originally Posted by cowboysfan
just ordered mine tonight so lets see how this improves the shifts..
Quick Reply: Loose shift stick?
