What injector and fuel setup for 450ci stroker
Looking for some suggestions on what type of injector to run. Looking for ease of tune, lbs, Hi or Low Imped, pintal or disk injectors and 07% - 80% DC.
I am hoping for low to mid 650hp+ @ the wheel and will be using a Vic Jr/4150 TB setup, Speed Density tune, 2000 ECU.
DM
DM
The Siemens 63's should be just perfect for what you want (Assuming this is an N/A build)
http://www.racetronix.biz/itemdesc.a...114961&eq=&Tp=
If boosted you could jump up to the Siemens 80's. And give yourself a good amount of headroom if you want more hp in future. (The 63's might just be able to support 650whp on boost depending on compression, tune, drive train loss etc..)
http://www.racetronix.biz/itemdesc.a...114992&eq=&Tp=
