LS4 Performance - need help fast!!
View Full Version : need help fast!!
Cubbie Fan
02-17-2011, 12:24 PM
Well I am in the middle of installing my poly motor mount, And I cant get the stock one out. Is there an easy way to get this thing out?
Haulin_Ls4_GxP
02-17-2011, 12:49 PM
U talking about the one on the core support
LS1>girlfriend
02-17-2011, 01:10 PM
If you're talking about the one on the core support and don't plan to use the mount anymore you can cut the mount out. I used a hole saw and it worked pretty good.
The best way to save the mount is to use a screwdriver/pry bar and pry it away from the metal bracket enough to squirt some hand soap between it and the rubber all the way around the mount. Then use a prying fashion and work one side of the rubber out of the bracket and the rest will follow. Hand soap is an excellent lubricant for rubber.
06MonteSS
02-17-2011, 01:49 PM
I lubed up all 4 sides of it with wd-40, then used a big flat-head screwdriver and just pushed it out in one whole piece...
piece a cake...
