LS3 into 2005 with M6?
the bottom end of my LS2 decided to retire itself last night. I found a real nice LS3 motor in the GM PP
https://store.gmperformanceparts.com...-19244549--%3E
has anyone put an ls3 into an ls2 m6 goat? will it mate to the trans? what else is needed as far as wiring, electrical, fuel? any help would be greatly appreciated
Thanks!
Thanks!
trans will mount and everything will fit but fuel rails and intake if it does not come with a rectangle port intake and i believe the reluctor wheel is 58 x where as ls1-2 are 24x. There are conversion boxes out i know that lingenfelter has one .
the crate motor comes with fuel rails and an intake, but will the exhaust line up? i have factory manifolds. and what about emissions? ecu? i am new to the LS world. ive had the car a week when the motor let go :-( wiring harness?
Made some calls this morning. Looking like the lingenfelter box and a reprogramming of the stock computer is pretty much all i will need and then its plug and play from there. Anyone else have any input from this?
i purchased the car from another forum user. it was in ABSOLUTE MINT condition. I was going for a 330 am blast down the highway and did something dumb. i blew it up.
Just get right reluctor wheel and cam gear changed! Everything else is plug and play. Makes for a much cleaner install and that'll be one less thing to fail and or worry about later on!
hey does anyone know where i can get a list of the specifications of the ls376. so i can send it to pcm4less. like the lb/hr of the injectors the degree of the cam and all that. rather long list. any help be greatly appreciated
