Pontiac G8 2008-2010 - Drag Pack
SLOW SEDAN
02-17-2011, 10:09 PM
Installed my Moroso studs and threw on my drag pack to hit the track tomorrow...
http://carphotos.cardomain.com/ride_images/3/3061/2109/32651054023_large.jpg
Compg
02-18-2011, 04:40 AM
Details on that drag pack please!
locrzn
02-18-2011, 05:31 AM
t
Thats gonna save some rotating weight. Looks good
SLOW SEDAN
02-18-2011, 06:00 AM
17" Greg Welds... rears are about 10lbs lighter then stock and the fronts are about 20lbs lighter. 275/40 17 MT ET Street Radials out back.
t
Thanks!
Devilish34
02-18-2011, 02:37 PM
Thats pretty close to the weight difference between my stocker and DP.
A3VETTE
02-18-2011, 04:20 PM
Looks pretty badass
SLOW SEDAN
02-18-2011, 06:39 PM
DP?
Looks pretty badass
Thanks!
Was enough traction to cut a new best 60' and go 128MPH today!
A3VETTE
02-18-2011, 09:08 PM
WOW!!!
still on the 100?
Devilish34
02-18-2011, 09:52 PM
DP drag Pack
SLOW SEDAN
02-19-2011, 09:38 AM
WOW!!!
still on the 100?
Yeah... car is a bit lighter now with a bit more tire under it.
DP drag Pack
Dragstar?
RedfoxGTO
02-20-2011, 01:25 AM
Sexy.. What wheels are those?
Codprice
02-20-2011, 07:19 AM
are those wheels safe for a daily? I like this look more than "stylish" wheels. more old muscle car look to it.
SLOW SEDAN
02-20-2011, 08:27 AM
Thanks, they are the Greg Weld ProLite wheels.
They are, its just if you want to put up with skinnies and drag radials on the street everyday. Put normal tires on them and should be fine for a daily.
I agree on the look! Debating on that color ring though.
You will have to swap out the studs to run them. The stock lugs are slightly too big but the Moroso studs are plenty strong and about a mm thinnner. Cost to swap studs was about $50 from Jegs and you also need new lugs which was another $30 or so.
SLOW SEDAN
02-20-2011, 08:35 AM
Also of note is that the Pedders suspension worked well on the track. I had to take the Eibach springs off due to the impact on my 60', with stock springs in the rear my 60' dropped back down lower then with the Eibachs. I was slightly worried that I would have to swap the rear springs back to stock again with the Pedders but they aren't as stiff as the Eibachs. I cut a 1.57 60' with the current setup which is fine with me!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
