Still grinding b/s 15x4
Bought some B/S 15x4 for the front of my f body.....spent 3 hrs ginding yesterday(on 1 side) and they still want fit.This is with a 1/4 in spacer.....%$#@@#@#$#$@@...If I had it to do over I wouldn't have bought them.
he has 15x4 2.25
ive always used 5/16th spacer in passed! Just did a search and saw a lot of others doing the same!
https://ls1tech.com/forums/wheels-ti...bs-spacer.html
Location: Your girl's back door giving her the long stroke while you're at work
They aren't a direct fit wheel, like said above they fit with a 5/16" spacer or grinding the calipers.
I had Draglites(ground down calipers) on my car prior to the Streetlites so they bolted right on
You should have bought the 15x4s with 1.625" backspacing, it's what 95% of guys on here are running that have the Streetlites
