Doing Fuel Pump Tomorrow Any Tips????
Gonna swap out the fuel pumps on the beast tomorrow ('01 camaro ss)
Just seeing if theres any useful suggestion to get it done right the first time!
Its a OEM replacement delphi pump.
I tested fuel pressure at the rail and got nothing w/ the key on.
Swapped relays with known good relay and got nothin.
So please if you have any input it would much appreciated.
Thanks!
Thanks!
depends...if you cut a hole in your trunk i would take only a hour or so, if your dropping your tank then take your time when it comes to pulling the pup assembly out and youll be fine. its not too hard!
