what tires for +1000RWHP ?
Hi like title says , Searched and didn't found any result for my 2001 Trans Am , let me explain to get the point well .....
* Car has LSX 454 + lot of nitrous and will pulls above 1000 at the wheels , exactly 400HP of nitrous (Direct port system - Progressive setup )
I bought Mickey Thompson ET radial Tires and didn't tested them yet
It has full suspension , RPM full built Transmission T56
All the car equipped by AES Racing , they're sponsor here
All races will be high rolling above 70MPH to avoid spinning issues
*So what tires u guys recommend for this car ?
*More one question ( I have Torque thrust II wheels the rear size 17inch width 11inch ) 335 /35R17 tires will fit ?
Do recommend to run 335 /35R17 ? , these tires will fit my wheels ?
http://www.summitracing.com/parts/KUM-1793313/
http://www.summitracing.com/parts/KUM-2105813/
you don't need to go wider, 10.5" can handle the power, so why u need to go wider, as photochop said, u need to go with taller wheel, then consider ur suspension, weight transfer, and stay away from kumho.
finally don't shot nitrous through gears .
